Processors
13531 Discussions
hardware actualizar
ariusgz
Procesador Intel® Core™ i5-8300H
caché de 8 M; hasta 4 GHz
se puede cambiar a uno mejor ? quiero mejorarlo un 7.8.9 generación
AndrewG_Intel
Hello ariusgz
Thank you for posting on the Intel® communities. Our support is only provided in English. We may not be able to translate screenshots attached to the thread. To better assist you, we use a translation tool.
We understand that you would like to upgrade the processor on your system.
The Intel® Core™ i5-8300H Processor is a mobile processor as per the information in the below link and it is most likely integrated on laptops or All-in-One systems >> https://ark.intel.com/content/www/us/en/ark/products/134876/intel-core-i5-8300h-processor-8m-cache-up-to-4-00-ghz.html
Only your system manufacturer is familiar with your system specifications and the processors it supports.
Before upgrading a mobile processor the recommendation is to check this with the system manufacturer (OEM) to validate that your system supports a processor upgrade and that the upgrade does not violate your warranty terms and conditions. Lack of BIOS support for your processor can cause the system to not boot or exhibit erratic behavior.
In this case, processor upgrade and BIOS update information is specific to the system motherboard and must come from the system manufacturer, and even if your processor and motherboard sockets match, it is critical to make sure that your system BIOS supports the new processor. Replacing a mobile processor can be difficult because the form factor is much smaller compared to a desktop system. Also, the processor may be soldered down on the motherboard.
A final consideration is that faster processors and processors with more cores can affect the temperature of your system, so the best recommendation is to address this inquiry to your OEM. You can find links to computer manufacturer support websites in this link*: https://www.intel.in/content/www/in/en/support/topics/oems.html
Note:
If you are interested in upgrading your current system with a new one with a Desktop processor, you may review this link for tips on how to find information on Intel Processors and how to compare Intel® Processors using Product Specifications Page (ARK):
https://www.intel.com/content/www/us/en/support/articles/000005682/processors.html
Andrew G.
*Links to third-party sites and references to third-party trademarks are provided for convenience and illustrative purposes only. Unless explicitly stated, Intel® is not responsible for the contents of such links, and no third-party endorsement of Intel® or any of its products is implied.
AndrewG_Intel
Hello ariusgz
We have not heard back from you so we will proceed to close this thread now. If you need any additional information, please submit a new question as this thread will no longer being monitored. It has been a pleasure to assist you.
Andrew G.
