Processors
Processors (Intel® Core™, Intel® Xeon®, etc); processor utilities and programs (Intel® Processor Identification Utility, Intel® Extreme Tuning Utility, Intel® Easy Streaming Wizard, etc.)
12943 Discussions
how can i run the 2nd core of the processor
lfara
i have intel core i7-4510U up to 3.1GHz and when i access to boot advanced options in system configuration i can't change the number of processor.
can you help me please.
Hello louay,
I understand that you are trying to "run" the 2nd core of the processor.
Regarding this, I would like to know what is the reason you are trying to run the 2nd core. Also, to mention that the core should run and activate on its own depending on the tasks at hand and the different applications. If the cores appear as inactive in the BIOS then I would recommend you to contact the manufacturer of your system so they can guide you and help you to change settings from the BIOS.
I hope this helps.
David V
Hello louay,
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
