Processors
14537 Discussions
how to check intel processor
aphat
hi every one
good morning
i purchase the new intel processor I3-6098P 3.6Ghz when i try to install windows 7 or 8 he show the Blue dump error
it happened more than 10 time i change the Ram & asus Motherboard but problem is same
how i can solve this i think it is the processor problem
so please suggest me how i can solve this ...
thank you
intel_adminjeremyhxbertCommunityAdminitpnadminBob_DuffyVidyaGovindan
Hi akshay23889: Thank you very much for joining the Intel® Processors communities.
Just to let you know, the processor has no operating system restriction, meaning that either Windows® 7 or 8 should work with it with no problems. However, the board does have a restriction in terms of the version of Windows that you can install. In this case since you already replaced the memory RAM and the board, then most of the times that indicates the problem could be the processor.
Remember that the proper memory for the processor should be: DDR4-1866/2133, DDR3L-1333/1600 @ 1.35V, please make sure that is the memory you are using and also you can test the PC using just one memory stick to rule out a possible problem with it.
Do you have the option to test the PC with a different processor?
If that option is not available for you, then you can try to replace the processor with the place of purchase depending on the warranty conditions they have, or we can always replace it for you. Remember the processor has 3 years of warranty with Intel and on the links below you will find the information to contact them:
Chat support: http://intelsupportchat.force.com/icslivechat/ics_tech_processor_ww_english_Chat http://intelsupportchat.force.com/icslivechat/ics_tech_processor_ww_english_Chat
For phone support, depending on your location, you will see the contact information on the links below:
EMEA contact information: http://intel.ly/28QeAF3 http://intel.ly/28QeAF3
APAC contact information: http://intel.ly/1ITfjUF http://intel.ly/1ITfjUF
LAR contact information: http://intel.ly/29c0rW4 http://intel.ly/29c0rW4
North America: Phone Number 1-916-377-7000, Monday - Friday 7:00 AM to 5:00 PM (Pacific Time).
Alberto R
