Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
how to use intel cmt cat on core x cpu
NOTE: Mixed use of MSR and kernel interfaces to manage
    CAT or CMT & MBM may lead to unexpected behavior.
INFO: CACHE: type 1, level 1, max id sharing this cache 2 (1 bits)
INFO: CACHE: type 2, level 1, max id sharing this cache 2 (1 bits)
INFO: CACHE: type 3, level 2, max id sharing this cache 2 (1 bits)
INFO: CACHE: type 3, level 3, max id sharing this cache 64 (6 bits)
INFO: Monitoring capability detected
INFO: CPUID.0x7.0: L3 CAT supported
INFO: L3 CDP is disabled
INFO: L3CA capability detected
INFO: L3 CAT details: CDP support=1, CDP on=0, #COS=16, #ways=11, ways contention bit-mask 0x600
INFO: L3 CAT details: cache size 25952256 bytes, way size 2359296 bytes
INFO: CPUID 0x10.0: L2 CAT not supported!
INFO: L2CA capability not detected
INFO: MBA capability detected
INFO: MBA details: #COS=8, linear, max=90, step=10
L3CA/MBA COS definitions for Socket 0:
  L3CA COS0 => MASK 0x7ff
  L3CA COS1 => MASK 0x1
  L3CA COS2 => MASK 0x7ff
  L3CA COS3 => MASK 0x7ff
  L3CA COS4 => MASK 0x7ff
  L3CA COS5 => MASK 0x7ff
  L3CA COS6 => MASK 0x7ff
  L3CA COS7 => MASK 0x7ff
  L3CA COS8 => MASK 0x7ff
  L3CA COS9 => MASK 0x7ff
  L3CA COS10 => MASK 0x7ff
  L3CA COS11 => MASK 0x7ff
  L3CA COS12 => MASK 0x7ff
  L3CA COS13 => MASK 0x7ff
  L3CA COS14 => MASK 0x7ff
  L3CA COS15 => MASK 0x7ff
So I got those output from my server, I am not sure about the cache and ways and how it allocated, is I want COS1 has minimum cache to use, how should I config it? pls tell
Tags (1)
Highlighted
Hello Jiangv,
Thank you for posting on the Intel* Community Forums.
Can you please confirm the following information?
  • Provide the specific model of your processor.
  • Are you using an Intel* server board? If so provide the model.
Maria R.
Highlighted
Hi Maria, Thanks
My cpu is a core i7 7980xe and running on x299 motherboard.
Highlighted
Hello Jiangv,
Thank you for the information.
We will look into this and posting back in this thread once an outcome is available.
Maria R.
Highlighted
Hello Jiangv,
Thank you for patiently waiting,
Please check the following sources:
If you need further assistance, our recommendation is to refer the questions to the Intel Developer Forums. There you will find more accurate information and assistance.
Maria R.
