Processors
16417 Discussions
how to use intel cmt cat on core x cpu
Jiangv
NOTE: Mixed use of MSR and kernel interfaces to manage
    CAT or CMT & MBM may lead to unexpected behavior.
INFO: CACHE: type 1, level 1, max id sharing this cache 2 (1 bits)
INFO: CACHE: type 2, level 1, max id sharing this cache 2 (1 bits)
INFO: CACHE: type 3, level 2, max id sharing this cache 2 (1 bits)
INFO: CACHE: type 3, level 3, max id sharing this cache 64 (6 bits)
INFO: Monitoring capability detected
INFO: CPUID.0x7.0: L3 CAT supported
INFO: L3 CDP is disabled
INFO: L3CA capability detected
INFO: L3 CAT details: CDP support=1, CDP on=0, #COS=16, #ways=11, ways contention bit-mask 0x600
INFO: L3 CAT details: cache size 25952256 bytes, way size 2359296 bytes
INFO: CPUID 0x10.0: L2 CAT not supported!
INFO: L2CA capability not detected
INFO: MBA capability detected
INFO: MBA details: #COS=8, linear, max=90, step=10
L3CA/MBA COS definitions for Socket 0:
  L3CA COS0 => MASK 0x7ff
  L3CA COS1 => MASK 0x1
  L3CA COS2 => MASK 0x7ff
  L3CA COS3 => MASK 0x7ff
  L3CA COS4 => MASK 0x7ff
  L3CA COS5 => MASK 0x7ff
  L3CA COS6 => MASK 0x7ff
  L3CA COS7 => MASK 0x7ff
  L3CA COS8 => MASK 0x7ff
  L3CA COS9 => MASK 0x7ff
  L3CA COS10 => MASK 0x7ff
  L3CA COS11 => MASK 0x7ff
  L3CA COS12 => MASK 0x7ff
  L3CA COS13 => MASK 0x7ff
  L3CA COS14 => MASK 0x7ff
  L3CA COS15 => MASK 0x7ff
So I got those output from my server, I am not sure about the cache and ways and how it allocated, is I want COS1 has minimum cache to use, how should I config it? pls tell
Maria_R_Intel
Hello Jiangv,
Thank you for posting on the Intel* Community Forums.
Can you please confirm the following information?
  • Provide the specific model of your processor.
  • Are you using an Intel* server board? If so provide the model.
Maria R.
Jiangv
Hi Maria, Thanks
My cpu is a core i7 7980xe and running on x299 motherboard.
Maria_R_Intel
Hello Jiangv,
Thank you for the information.
We will look into this and posting back in this thread once an outcome is available.
Maria R.
Maria_R_Intel
Hello Jiangv,
Thank you for patiently waiting,
Please check the following sources:
If you need further assistance, our recommendation is to refer the questions to the Intel Developer Forums. There you will find more accurate information and assistance.
Maria R.
