Processors
14539 Discussions
hp pavillion g6
salve a tutti
premetto che non sono per niente ferrato in merito all'argomento ma vorrei avere delle info.
Allora... io ho un Hp Pavillion g6 che monta in i3-2310m e vorrei sostituire il processore con uno più "potente" ma non so se è possibile (per questo chiedo).
Qualora fosse possibile, quale gamma di processore potrei montare?
io avevo pensato ad un i7-740QM
aspetto delucidazioni
Hello xxfire89xx:
In regard to your question, in order to make sure if the Intel® i7-740QM processor will work with your laptop the best thing to do will be to get in contact with HP directly, they should be able to let you know if it is fully compatible and the might be able to provide a list of compatible processors, the reason for that is that even though the processor has the same socket as the board in the laptop, that does not mean it will work because the microcode on the BIOS should support it, since HP is the manufacturer of the laptop and they install the BIOS they should be able to provide the information you need.
Any further questions, please let me know.
Alberto
Hello xxfire89xx:
I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Alberto
