Processors
14501 Discussions
işlemcimin base ve turbo frenkansı aynı bu normal bir durum mu?
aayva
merhaba
Intel® Core™ i7-4712MQ Processor model işlemciye sahip bir laptop kullanıyorum bu gün dikkatimi çekti base frekansı ile turbo frekansı 2.30 ghz bu normal bi durum mu yardımlarınız için şimdiden teşekkür ederim :)
https://ark.intel.com/products/78933/Intel-Core-i7-4712MQ-Processor-6M-Cache-up-to-3-30-GHz-?q=Intel%20Core%20i7-4712MQ işlemcinin adresi
RAJU2529
New Contributor III
At first your processor belongs to laptop or notebook , so manufacturers has already customized and fixed base frequency than by intel .
while using in normal applications , base frequency is normal . try to run heavy graphics applications like autocad or solid works 64 bit or play need for speed payback edition , you will max turbo frequency .
my asus laptop uses i5 7200u its base freq fixed by intel is 2.5Ghz , but asus fixed as 2.71GHz and when I play heavy 3d applications I get 3.10 Ghz ( turbo freq )
