Processors
13872 Discussions
i have just upgraded my Cpu from the factory standard CPU to a duel core processor but i believe the OS is struggling to identify which processor to use. how can i f ix this?
cdodd1
i have an Acer Extensa 5230e and i have upgraded the processor from a Intel 2.16/1m/667 to a intel duel core 2.20/4m/800 t7500
O/S windows 7 ultimate 32-bit
bios v1.29
graphics informatio mobile intel 4 seris express chipset family
2 physical cores
2 logical cores
when i start the laptop it boots up into a bios type screen v1.29
it detects 1 processor with 2 cores to a processor,
it reconises 2 of the 4 gig of ram installed
4096 kb l2 cache.
system and video bios shadowed
fixed disk 0 :wdc wd1600bevt - 22zcto
atapi cd rom
02f0 cpu id fb no microcode update loaded for alternative processor
it then says to continue press F1, once i do that windows boots up and all seems to run fine,
Ive run the Intel Processor Diagnosis tool and it stops scanning and fails at brand string, when i turn off the "stop testing on fail" the rest of the scan passes everything. under the CPU1 box on the bottom right i get the following script (ill post it all as i dont know what will be of interest.
--- Genuine Intel Test ---
Version 1.0.16.32b.W
Expected -- GenuineIntel
Detected -- GenuineIntel
Genuine Intel CPU Module Success
--- Brand String Test ---
Version 1.0.20.32b.W
IntelR CoreTM2 Duo CPU   T7500  2.20GHz
Brand String Module Fail....
 --- Cache Test ---
 --- Reading Cache Size ---
 - Detected L1 Data Cache Size -- 32
 - Detected L1 Inst Cache Size -- 32
 - Detected L2 Cache Size -- 4096
 - Detected L3 Cache Size -- Not detected.
Cache Module Success
 --- MMXSSE Test ---
Version 1.0.22.32b.W
..DetectUtils DLL Version - 1.1.2
 --- Determining MMX - SSE capabilities ---
..MMX is supported on this CPU..
..SSE is supported on this CPU..
..SSE2 is supported on this CPU..
..SSE3 is supported on this CPU..
..SSSE3 is supported on this CPU..
..SSE4.1 is NOT supported on this CPU..
..SSE4.2 is NOT supported on this CPU..
--- Integrated Memory Controller Test ---
Version 1.0.17.32b.W
--- IMC NOT Supported on this Processor ---
--- Integrated Memory Controller Test NOT Supported on this Processor ---
..Skipping Integrated Memory Controller Test..
Parallel_PrimeNum
Version - 1.0.0.9
--- Floating Point Test ---
Version 1.0.19.32b.W
AVX is NOT supported in your OS
FMA3 not supported
MFLOPS      CycleRun    Error    Timesec
 --- AVX Test ---
Version 2.0.22.32b.W
 --- CPU Features Detection ---
..AVX is NOT supported by this CPU..
..AVX2 is NOT supported by this CPU..
..AVX512BW is NOT supported by this CPU..
..AVX512CD is NOT supported by this CPU..
..AVX512DQ is NOT supported by this CPU..
..AVX512ER is NOT supported by this CPU..
..AVX512F is NOT supported by this CPU..
..AVX512IFMA52 is NOT supported by this CPU..
..AVX512PF is NOT supported by this CPU..
..AVX512VBMI is NOT supported by this CPU..
..AVX512VL is NOT supported by this CPU..
..AES is NOT supported by this CPU..
..PCLMULQDQ is NOT supported by this CPU..
..AVX is NOT supported by this Operating System..
Most Advanced AVX Feature Detected.. No AVX features found
AVX Test - Not Tested
AVX2 Test - Not Tested
AVX512 Test - Not Tested
Minimum Operating System requirements are
Windows 108.187 SP1 Windows Server 2008 R2 SP1
AES Test Result --- Not Tested
PCLMULQDQ Test Result --- Not Tested
 --- FMA3 Test ---
Version 1.0.19.1.32b.W
..FMA3 is NOT supported by this CPU..
..FMA3 is NOT supported by this Operating System..
FMA3 not supported
any help will be greatfully reciveed
AlHill
We do not need all that information.
You need to ask ACER what processors are supported by THEIR bios. Then, you can select from those.
If you are having trouble with Windows 7, sorry, windows 7 is dead and there is no support here for obsolete/discontinued products.
Doc
