Processors
13536 Discussions
i3-4150 3種電壓 CPU VRM CPU VOD CPU VCORE 核定範圍是幾V到幾V
JJKL0
Esteban_C_Intel
Hello JJKL0,
I would like to inform you that our support is only provided in English. To properly assist you, we use a translation tool.
To better assist you, could you please provide us with more information about the issue you are having or the inquiry you have? Also, could you please provide us with your motherboard model?
Esteban Ch.
A Contingent Worker at Intel
INTEL幹你娘老機掰烏龜王八蛋拒給答案
I3-4150
3 kinds of voltage
CPU VRM
CPU VOD
CPU VCORE
The approved range is a few V to a few V
MB:B85-G43 GAMING​
Esteban_C_Intel
Hello JJKL0,
Thank you for your response,
Could you please confirm if the issue you are having is that the Voltages of the CPU are different while running different tests? If this is not the issue please provide a detailed description of the issue you are having.
Esteban Ch.
死官方拿電壓有所變動為理由拒絕回應
可正常工作電壓是幾V到幾V
根本就想陷害人無法分辨觀察CPU電壓合理範圍
避免主機板電源供應器燒壞CPU或不能正常使用
如果我點出來此疑慮
你這個死INTEL官方下一句是否會稱說請向主機板POWER原廠詢問
主機板POWER原廠稱不在他們的業務範圍內好嗎
​單位都在互踢皮球去吃屎特龍算了
Esteban_C_Intel
Hello JJKL0,
I would like to point out that the voltages are set by the motherboard; therefore, if the processor is getting different voltages the motherboard is the one who is providing it with different values.
Also, different readings are ok since they are captured in different workloads (BIOS vs OS) This is expected and normal. If you still think the voltages are an issue please run the IPDT (Intel® Processor Diagnostic Tool) to make sure CPU is working fine.
Esteban Ch.
Esteban_C_Intel
Hello JJKL0,
I would like to know if you need further assistance? If so, run the IPDT (Intel® Processor Diagnostic Tool) to make sure CPU is working fine.
Esteban Ch.
Esteban_C_Intel
Hello JJKL0,
We have not heard back from you, so we will close this inquiry. If you need further assistance, please post a new question.
Esteban Ch.
