i have tested my cpu in some benchmark apps to check its performance . the cinebench test was simillar to the other benchmarks in internet, but the other tests like 3dmark, geekbench and xtu2 are diffrent and fewer than scores that published by others. is there any problem with my cpu or the benchmarks are not reason to check it.
i didnt overclock my cpu
MB:z690 ddr4 gigabyte
ram:corsair 3200 ddr4
GPU: 3070 ti inno3d
power: deepcool p850 gold
cpu cooler : deeo cool gammaxx L240
ssd: WD s570 500tb
my scores:
cinebench : single 1918 multi 17660
3mark time spy : 10500
xtu2 : 6000
in xtu2 test my max core frequency is -3.7 ghz
i checked my cpu with intel diagnostic tool and every thing was ok.
Hello mobinoveisi,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel® Core™ i5-12600K Processor.
In this case, I would like to let you know that the performance of a processor also depends on the cooling solution, case airflow, RAM model/brand, temperature of the room, etc. If the CPU does not get the desired or max results in a benchmark it does not necessarily mean that there is something wrong with the CPU.
However, in order to better assist you, please provide the following:
1. Can you take a picture from "XTU2" where we can see the frequency?
2. Have you noticed any issues with apps and games? If so, which apps and games?
3. Have you noticed any blue screen of death or crashes with this processor?
4. Based on your post, the CPU is not reaching the results desired. which results are you comparing the CPU to or what are the results desired?
5. Can you provide more details about the issue?
Deivid A.
Hello mobinoveisi,
Were you able to check the previous post and get the information requested? Please let me know if you need more assistance.
Deivid A.
Hello mobinoveisi,
I was checking your thread and see that we have not heard back from you.
I’m going to close your post, but if you need further assistance, please do not hesitate to create a new thread.
Deivid A.
