Processors
16002 Discussions
i5 14600k temperatures
Furlanetto
Hi everyone.
I recently got an i5 14600k (up from my 12700k - I don't have a solid reason for the upgrade other than catch up with the latest generation my motherboard supports) and I have been freaking out about the temperatures I am getting under the same workload as my 12700k.
For example: while gaming (World of Warcraft) my i7 12700k hit about 68 degrees max, while the i5 14600k peaked 90 degrees on the same environment.
The temperatures on idle are approximate, but the i7 12700k runs a little cooler than the 14600k.
Even under stress tests and benchmarks, I have never seen the 12700k get higher than 90s degrees, while my first benchmark on intel XTU (didn't change any settings) on the 14600k pushed it to 100 degrees.
Should I be concerned? I am attempted to return and/or selll the 14600k and keep my 12700k for peace of mind, but then I'd have to put a fight against the retailer that sold me the CPU because it's past the return date by 2 weeks (return policy in Brazil is 7 days after getting the product).
My system:
Asus ROG B760-I
32gb kingston renegade 6400mts DDR5
AIO Masterliquid 240mm
PSU Corsair SFX750w
RTX 3080 Gigabyte Vision
Samsung 980 PRO 1TB
I must say that this is an ITX build (meshlicious case), so it's got a decent airflow.
I am thinking about undervolting the 14600k, but I'm not really comfortable. Any tips or suggestions are appreciated.
Thanks in advance.
Anonymous
Not applicable
Din câte văd eu, ai aceeaşi problemă ca majoritatea. Chiar dacă aveți cea mai recentă versiune bios (sau dacă nu, ar trebui să o actualizați urgent (CPU Microcode 0x12B) https://rog.asus.com/motherboards/rog-strix/rog-strix-b760-i-gaming-wifi-model/helpdesk_bios/ . Tensiunea VID (Max) atinge 1500V în măsura în care văd de la dvs., ceea ce înseamnă că încărcarea CPU Lite este setată la modul înalt 22, de exemplu, modul în care a fost setată pentru mine și liniile de încărcare au fost AC 170 / DC 170. Așa a venit cu actualizarea bios-ului fiind ultimul, mă îndoiesc **bleep** ar trebui să fie setat la 14600k, am folosit Modul 12 adică Ac 70 / Dc 110!
unde a ajuns la 1.368 V. Nici măcar nu știu dacă aceasta este o tensiune corectă, acum am setat Modul 9, adică Ac 40 / Dc 110, tensiunea fiind de 1.311 V, Dar modul 9 reduce oarecum performanța mea. Pentru a vedea liniile de încărcare în bios trebuie să mergeți la "Cpu Lite Load Control și apăsați Advance, apoi liniile de încărcare sunt afișate pentru modul care este setat", am pus și întrebarea aici pe forum care sunt liniile de încărcare corecte, dar fără nici un rezultat "INTEL "el doarme așteptând un răspuns din octombrie și nici un răspuns.
Furlanetto
Hey!
Thank you for replying.
I gave up on this CPU and sold to another guy who is willing to deal with all these settings. I am back to my i7 12700k which is working perfectly fine out of the box.
