Processors
14539 Discussions
i5-2500K not seeing 4 DIMMs worth of memory
Hey folks,
I recently ordered an i5-2500k and a new ASUS motherboard. I got it all hooked up and turned out that the PC would not POST with 4 DIMMS worth of memory in. I immediately figured this was a MoBo issue and replaced it with an MSI Z77A-GD65. Upon hooking everything up, I found the same issue to be prevalent.
So, thanks to my stubbornness, I look up compatiable RAM and sure enough, mine is not listed as compatible. So, I pick 16 GB of RAM that is compatible install all 4 DIMMS and I still cannot POST. I can post with 2 DIMMS (8GB) fine.
I contacted MSI who told me that it was because there was a bent pin on my processor. I unseated the thing and checked it out and it looks clean as a whistle. MSI will no longer offer any support. This thing is less than a month old. I'm at a loss here and was hoping someone in the Intel community might be able to steer me in the right direction.
PC Specs:
i3 2500k
MSI Z77a-GD65 Motherboard
gSkill F3-12800CL9D-8GBRL RAM
800 Watt Corsair PSU
EVGA 570
Jose_H_Intel1
Hello Josh,
Your i5-2500K supports memory up to 1333 MHz at 1.5v as shown below:
http://ark.intel.com/products/52210/Intel-Core-i5-2500K-Processor-6M-Cache-up-to-3_70-GHz http://ark.intel.com/products/52210/Intel-Core-i5-2500K-Processor-6M-Cache-up-to-3_70-GHz
The Gskill memory you have is rated at 1600 MHz so it does not seem to be compatible.
http://www.gskill.com/products.php?index=239 http://www.gskill.com/products.php?index=239
You may also try to reset the BIOS and update it.
Besides that, if there is a chance the socket in the motherboard has bent pins you may need to swap the motherboard or the processor with another one in order to determine the faulty component.
Jose_H_Intel1
Hello Josh,
Hey Joe,
Turns out that upon further inspection, the pins on the motherboard socket are bent to heck and back. I am surprised I was able to get it working at all. I am sending it back for return today and purchasing a different one.
Thanks for your help~!
