Processors
13170 Discussions
i5-4570TE thermal specs
AAnto6
Hi all.
We have a project on we was using i5-4590T for a time without problems. Due this processor is EOL we switch to i5-4570TE.
We select the i5-4570TE as replacement due they have the same TDP. These two processors have 35W TDP, but the second proccesor is reaching 90ºC. We are using the same heatsink that we were using with the i5-4590T.
Why this processor overheats if it has the same TDP that the previous model? Is not the TDP a valid measure of the thermal specification? There is a typo on the i5-4570TE TDP?
Thank you.
Thank you very much for taking the time to reach the Intel Communities Team, NewData. I will do my best to assist you further.
In this case, for us to provide you with better assistance, please share this issue with our Embedded Support Team so we will be able to provide you with a solution as soon as possible: https://embedded.communities.intel.com/community/en https://embedded.communities.intel.com/community/en
Antony S.
Antony S.
