Hi all,
I'm owning an i5-4590T CPU which I'm using for a small NAS server with a MB (Chinese JGINYUE H97I-GAMING) that uses H97 chipset.
It has only 2 memory slots. In the specs of the CPU says that it supports 32GB on dual-channel, but what I can't find in the specs which is the maximum DIMM capacity.
From the MB it says that maximum capacity is only 16GB, from which I can understand that the maximum DIMM size should be 8GB.
There are some DDR3 with 16GB capacity but mostly have a mention to be used only for AMD.
Could anybody please help me with this information?
Kind regards.
Thanks for the info. Maybe I can buy one stick of DDR3, test it and check if is working. In case is not working I will return it back to the shop.
The only way see if is working is to test it.
I thought there is a CPU limitation that is not supporting 16GB memory stick, but looks like more a MB / BIOS limitation.
