Processors
14530 Discussions
i5-6500 100% use
Gauthierr
i bought i5-6500 but it's totally used it's marked 100% use so it's lagging my pc help plz
AlHill
So the Intel support engineers can have more information about your system, Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file using the instructions under the reply window ( Drag and drop here or browse files to attach ).
Gauthierr
its good and im french so maybe they are french in my folder sorry
AlHill
I cannot see the model number of your asustek motherboard, and I cannot see your bios revision.  Do you have that information?
Also, I assumr you built this PC, is that correct?  Have you considered the installation of the processor needs to be done again?
This "100%" - is that only for a few minutes after startup, or all the time?
Have you checked your startup programs?  Do you have lots of PUPs installed?
Gauthierr
1. i don't have built my pc
2.The "100%" its all time
3. i have took screenshot of informations bios/mother board
4. my pc is old (4 years)
5. Have you checked your startup programs? Yes
6.Do you have lots of PUPs installed? Yes
AlHill
I would start by disabling some of the startups.  But, if you do have lots of PUPs, you should get rid of them.  MALWAREBYTES.ORG does a particularly good job of identifying and removing PUPs.  And, it is free.  Just download it and clean up your machine.  I just ran that on a friends machine and it removed 234 PUPs.  It took two passes, but the PUPs are gone.   And, it may identify other viruses.
After that, let us see where you are.
n_scott_pearson
For the 100% usage, please open Task Manager, select More Details (lower left corner), select the Processes Tab and then select the CPU column (so it sorts processes by utilization). Take a snapshot of this display and attach it to a response message.
I would also like to see a thermal sensor display from a program like AIDA64, HWiNFO64 or something similar.
