Processors
16296 Discussions
i5 7400 se cuelga
bacho
mi procesador intel core i5-7400 se cuelga y se me congela toda la pc a los 20 minutos de uso y me toca reiniciar para que se descongele y a los 20 minutos se vuelve  acongelar
alguien sabe el por que o alguna solucion por que esta todo en prefecto estado ( el cooler la pasta termica ) pero no se que mas puede pasar
Alberto_R_Intel
bacho, Thank you for posting in the Intel® Communities Support.
Solo para informarle, solo brindamos soporte en inglés y, actualmente, estamos utilizando una herramienta de traducción.
We are sorry to hear about this issue and we will be more than glad to assist you with this matter.
In order for us to provide the most accurate assistance on this topic, we just wanted to confirm a few details about your system:
What is the model of the motherboard?
Is this a new computer?
Did you build it?
Was it working fine before without showing the freezing issue that you are describing?
If yes, when did the issue start?
Did you make any recent hardware/software changes that might cause this problem?
Which Windows* version are you using?
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
Alberto_R_Intel
Hello bacho, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Hello bacho, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
