Processors
14526 Discussions
i5 7500 cpu oyunlarda %100 olarak kullanımda gözüküyor. 2009/1 serisi eski i7 270 işlemci artı olarak 4 mantıksal işlemci fazla olmasına rağmen %40 kullanım gösteriyor. Acaba yanlış yaptığım bir şey mi var yardımcı olur musunuz ?
UDAĞ
Wanner_G_Intel
Hello UDAĞ, Thank you for joining this Intel Community. Some games are processor intensive games. Others are GPU intensive games. It is usually expected to get 100% CPU usage while running intensive games. However, we recommend checking the following information: 1. Are you running other demanding applications or games at the same time? 2. What is the processor usage when running other applications or navigating through the Internet? 3. What is the CPU usage when it is idle? 4. Please list the games you usually run and your system configuration. You can run the Intel® System Support Utility and attach the report to this thread, too. 1.Download the Intel® System Support Utility and save the application to your system. https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600 2.Open the application and click Scan to see system and device information. The Intel® System Support Utility defaults to the Summary View on the output screen following the scan. Click the menu where it says summary to change to Detailed View. 3.To save your scan, click Next and click Save. You can save the file to any accessible location on your computer. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
UDAĞ
sadece chrome tarayıcı açıkken %33 İşlemci boş ta çalışırken %3 te çalışmaktadır. Oyunda %100 Sürekli Olarak oynadığım oyun playerunknown's battlegrounds. Önerdiğiniz bilgiler ekte mevcuttur. Teşekkürler
Wanner_G_Intel
Hello UDAĞ, Thank you for your response. Based on the information provided, the CPU utilization you are getting is expected. This may also vary depending on the settings you are running the game with. Since you are using discrete graphics, you can try low settings for testing purposes. Now that we know that you are using discrete graphics, please share more information about the GPU utilization, too. Are you getting high temperatures? Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
UDAĞ
sıcaklık değerleri % 50 'i geçmemektedir. Sıcaklık değerlerimin normal olduğunu düşünüyorum. Daha yüksek bir ekran kartı taktığımda (1070ti) uyumsuzluk yaşamaktan korkuyorum. Bir sorun olur mu ?
Wanner_G_Intel
Hello UDAĞ, Do you mean compatibility issues between the graphics card and the processor? In this case, you may need to contact your motherboard manufacturer to make sure the graphics card is compatible with your system. If temperature is not an issue, and the performance of your system or game (e.g. fps) is not impacted, then your computer is running within specifications. However, pay attention to the following information: 1. Make sure your power supply is meeting the power supply wattage required. 2. Load default BIOS values. 3. You may also go to Windows* Power Options and make sure that High Performance is selected. 4. If you can test another graphics card, then it will be interesting to see if the behavior persists. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
UDAĞ
Bu söylediklerim şuan için bir sorun oluşturmuyor. İşinizi iyi yapıyorsunuz bana yardımcı olmak için gösterdiğiniz gayret için teşekkür ederim.
