Processors
14539 Discussions
i5 8250 u turbo boost disabled?
BUdre
I bought this leptop like a month ago, but never tested the max frequecy that it can reach. I installed Intel Extreme Tuning Utility and discovered that the Intel Turbo Boost feature was disabled, and can't enable it. In the bios does't appear nothing about it. Any suggestions how to eable it?
Hello bodo4549,
I understand that you are having problems with the Intel ® Turbo Boost technology as it appears to be deactivated from your system.
Regarding this, I actually would suggest you to contact the manufacturer of your motherboard/laptop in order for them to guide you step by step to activate the Intel ® Turbo Boost. That technology is something managed within the BIOS by the OEM (Original Equipment Manufacturer).
David V
Hello bodo4549,
I am following up with your case and see that we have not heard back from you.
If you need more assistance do not hesitate to reply.
David V
