what are the normal temps like at idle (or) browsing web for i5-8400 processor
That depends upon (properly applied) cooling solution. You should be able to achieve high 30s or low 40s with good liquid cooling or heat pipe solution.
If you are having a problem, spit out its details and it can be discussed.
Thanks N. Scott Pearson for reply
my temp are at 29c to 45c when iam like browsing.
iam using liquid cooler
Those temps are fine. So what's your issue?
I just what clarity
thanks for the reply
