Processors
Processors (Intel® Core™, Intel® Xeon®, etc); processor utilities and programs (Intel® Processor Identification Utility, Intel® Extreme Tuning Utility, Intel® Easy Streaming Wizard, etc.)
12598 Discussions
i5 - 9400 's compatibility with DDR4 - 2400.
T18
Hi folks!
I'm about to buy an i5 9400, but i'm worry about the RAM. Intel says that i5 9400 can work with a DDR4 - 2666 memory. Does that mean it *only* works with that type of memory? Or could it work with a DDR4 - 2400 memory?
I'm basically a newcomer, so I would really apreciate a detailed, referenced answer.
Thank you!!
AlHill
You are buying the i5-9400, presumably for your motherboard. Does your motherboard support the i5-9400 (with its BIOS), and does your motherboard support DDR4-2400?
Doc
n_scott_pearson
Super User Retired Employee
Intel specs the highest clock speed that they validate (in this case, 2666 MHz). Lower speeds (2400 and 2133 MHz) are always supported and validated. Higher speeds (3000+ MHz) are not guaranteed but may also be supported, depending upon the quality of the motherboard in question and its BIOS support.
Hope this helps,
