Hi, for some odd reason my CPU (i5 9400F) is not running at the base voltage (which is read is 1.246, correct me if i'm wrong)
All monitoring software show it at 0.274 and i'm getting constant stutters playing games.
Any help is appreciated.
Hello colezzz,
To better assist you can you please provide the following reports and information:
IPDT
Run the Intel® Processor Diagnostic Tool and send the results either in a .txt file. To save the report, once the test is done, click on "File >> View Results File" and attach the .txt file to your reply.
https://downloadcenter.intel.com/download/19792
DXDIAG
- Go to Start > Run or Windows Key + R.
- On the Run prompt, type "dxdiag" then click OK.
- On the DirectX Diagnostic Tool window, click on Save All Information.
- Browse to a folder, type in a filename then click Save.
Use the option under the reply window to attach the report to the thread (Drag and drop here or browse files to attach).
- What software are you currently using to check the processor’s voltage?
- Have you change any BIOS settings?
- Were you able to see normal readings in terms of voltage before?
- If yes, was there any recent change related to the point when the issue started?
- Can you please show provide some pictures of the reading you are getting?
- What games are you having issues with exactly?
I look forward to hearing from you.
Victor G.
Intel Technical Support Technician
Hello colezzz,
Please let me know if you need further assistance.
Victor G.
Hello colezzz,
We have not heard back from you.
Victor G.
