I have a simple question.
If I do not overclocking, i5-9600K is suitable with Intel default cooler(non-K bundle cooler)? Default cooler can recommend for i5-9600K?
I want to get an official answer from the technical support team.
Seong-Jin Roh
By definition, the coolers supplied by Intel will support your processor in all standard configurations. Overclocking configurations will likely require an alternate (higher wattage and/or higher mass) solution, however -- and that is why no cooler is packaged with the K processors.
Thank you for your reply.
I have a one more question.
If I use i5-9600K with H370 mainboard. This configuration is cannot overclocking. In this situation, can I use coolers supplied by Intel? CPU temperature is good for use?
Seong-Jin Roh.
If you are not overclocking, then yes, you can -- provided that the cooler you choose supports 95W processors.
