Processors
Processors (Intel® Core™, Intel® Xeon®, etc); processor utilities and programs (Intel® Processor Identification Utility, Intel® Extreme Tuning Utility, Intel® Easy Streaming Wizard, etc.)
12444 Discussions
i5 desktop processor 7500 earlier supporting 16 gb ram , now it is supporting only 4 gb ram. if nore than 4 gb ram installed then no display condition happens. please explain . i had already replaced my cpu then also problem existed.
pbhoy
AlHill
Download, run, and attach the results of this utility:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then, an Intel support engineer can assist you.
Doc
pbhoy
system information extracted from my system. currently mys system is working on 6500 intel core i5 porocessor.
Wanner_G_Intel
Hello pbhoy, Thank you for attaching the report. To better assist you, we would like to confirm the following information about your setup. 1. The report attached shows that you are using the following memory and processor: *Intel® Core™ i5-6500 Processor *Physical Memory (Installed):"16 GB" F4-2400C15-16GVR Since you were able to boot into Windows* to pull this report, how often does this behavior occur? Could you please confirm if this is the memory you are using? https://www.gskill.com/en/product/f4-2400c15d-16gvr We could not find the product specifications with this part number: F4-2400C15-16GVR 2. This specific memory (F4-2400C15-16GVR) is not listed among the compatible memory for this motherboard. Have you tried using another memory stick? SUPPORT FOR B250M PRO-VDH Compatibility https://www.msi.com/Motherboard/support/B250M-PRO-VDH#support-mem-4 Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
Wanner_G_Intel
Hello pbhoy, If you have any further questions, we will be glad to assist you. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
Wanner_G_Intel
Hello pbhoy, If have any questions, please contact us back. Wanner G. Intel Customer Support Technician Under Contract to Intel Corporation
