Hello 一个狂野的b友,
请注意,我只能用英语为您提供支持。我使用了网络翻译工具来翻译此回复,因此,可能会有一些不准确的翻译.
To answer your question, your i7-13620H processor, which has Intel® UHD Graphics for 13th Gen, can be turned to Iris Xe Graphics.
To achieve this, you need to ensure that your laptop is using dual-channel RAM. Typically, your laptop has two RAM slots. For the UHD Graphics to be recognized as Iris Xe, you need to insert another RAM module to enable dual-channel mode. This way, your system will recognize your graphics as Iris Xe.
For more information you can check this article:
Why Does an Intel® Iris® Xe Graphics Eligible System Show It Is Using Intel® UHD Graphics?
Thank you for visiting and posting in the community. If you need further assistance, please submit a new question, as this thread will no longer be monitored.
Dhanniel M.
