Hello. Does anyone have tested the real maximum frequency of ddr5 RAM that can be used by this processor?
Will 7200-7600 run?
Hello Bogodist777,
Based on the specification of the i7-13700K, it can only have DDR5 5600 MT/s and DDR4 3200 MT/s.
You may check out this link for the specifications of the i7-13700K:
If you have any questions, please let me know.
Thank you, and have a great day ahead!
Carmona A.
Hello Bogodist777,
I wanted to check if you had the chance to review the information we posted. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Still, I would like to inform you that, the Intel Core i7-13700K CPU officially supports DDR5 memory speeds up to 5600 MT. While some motherboards may offer support for higher memory speeds and enable them through XMP settings, these are considered overclocking and are not guaranteed by the CPU's specifications.
Regarding the specific frequencies of 7200-7600 MHz, this would be significantly beyond the official support and would depend on the individual components' capabilities, including the motherboard and the RAM itself. It's also important to note that achieving such high frequencies may not be stable on all systems and could require advanced cooling solutions and careful tuning.
For more information, you can check the following articles:
Supported Memory Type for Intel® Core™ Desktop Processors
How to Find Max Memory Size, Max Speed, and Max Bandwidth for Intel® Processors
Norman S.
buenas, entonces los procesadores i7 13700 kf soportan las frecuencias de ram de 7600mhz o no, querria saberlo por que yo tengo un modulo de 32gb a 7600mhz y la placa base soporta hasta 7800mhz
Hello Bogodist777,
May we know if you have any additional queries or require further explanation? Please know that we would be happy to assist you if you have any.
Thank you, and have a great day!
Carmona A.
Hello Bogodist777,
Norman S.
