Processors
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
14272 Discussions
i7-13700kf stuttering in games
Manuben
Hi, I have a stuttering problem with my i7-13700kf.
When I play games my games run smooth but randomly the start to lag a lot. CPU usage drops from 50% to 10%.
My motherboard is ASUS PRIME Z790-P D4 and I have 4 sticks on DDR4 3200Mhz ram
Manuben
The problem it's solved.
I dont know what fixed it but changed ram xmp to manual with same values, reinstalled graphics drivers using DDU
AlHill
Update your bios, and make sure you correctly installed your cooling solution.
Manuben
Thanks for your reply.
I already tried updating bios (0602) but not addressed the problem. Also updated GPU drivers to latest.
My cooling solution, it's a NZXT Kraken 360 mm AIO.
AlHill
As I said, make sure your cooler (and thermal paste) are correctly installed.
Manuben
alex2019
I'm facing the same issue. Can you please advice?
