CPU: i7-14700k
Motherboard: ASRock Z790 PG-ITX/TB4, XMP and Intel Dynamic Tuning Enabled.
Memory: G.SKILL Ripjaws S5 Series 64GB F5-6000J3040G32GX2-RS5K
Do I have a defective CPU or is there a default setting in the BIOS causing this behavior?
HWiNFO.CSV is the log file for this R23 run.
Kolchak, Thank you for posting in the Intel® Communities Support.
We are sorry to hear about this issue and we will be more than glad to assist you with this matter.
In order for us to provide the most accurate assistance on this scenario, we just wanted to confirm a few details about your system:
Is this a new computer?
Was it working fine before without showing the Thermal Throttling issue that you are descrbing?
If yes, when did the issue start?
Did you make any recent hardware/software changes that might cause this problem?
Albert R.
Hello Kolchak, I just wanted to check if you saw the information posted previously and if you need further assistance on this matter?
Albert R.
Hello Kolchak, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
