Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
i7 2600 - Questions about stock cpu fan speed
I recently bought an i7 2600 CPU with a ASUS P8H67-V motherboard.
I did a check on temperature by software, and i saw that the fan had a speed of +2300 rpm in load (60+ degrees)
I would like to know if the speed is normal. Because i read before that the fan have a max to 2000 rpm only.
In idle it's at 1300-1400 rpm. And the temp are idle : 37 - load : 68-69.
the speed is a problem ? will it broke quickly at that speed ? is it normal and i don't have to panic ?
thanks for your help
Re: i7 2600 - Questions about stock cpu fan speed
2300 RPMs is totally normal for an Intel fan speed, so there is no reason to worry about it.
Fan speed can go over 4000 RPMs
Highlighted
Community Manager
Thanks a lot for your response.
