I recently bought an i7 2600 CPU with a ASUS P8H67-V motherboard.
I did a check on temperature by software, and i saw that the fan had a speed of +2300 rpm in load (60+ degrees)
I would like to know if the speed is normal. Because i read before that the fan have a max to 2000 rpm only.
In idle it's at 1300-1400 rpm. And the temp are idle : 37 - load : 68-69.
the speed is a problem ? will it broke quickly at that speed ? is it normal and i don't have to panic ?
thanks for your help
2300 RPMs is totally normal for an Intel fan speed, so there is no reason to worry about it.
Fan speed can go over 4000 RPMs
