Hey guys
I have overclocked my igpu to 1650Mhz and offset voltage 0.25v with asus turbo v pro.
(motherboard : P8Z68-V PRO)
I want to increase the frequency but it gets unstable. So is it safe to increase the igpu offset voltage without damaging my cpu
Thanks for your help.
Currently, Intel does not recommend doing any type of over-clocking, since that will force the processor or even the graphics controller to run out of specifications, hence the system will become unstable.
The Intel recommendation is to use the system at the default settings, so it will be running under the specifications that it was designed to run.
