Processors
16316 Discussions
i7 2700k memory manager must be bad
cphil5
I have come to the conclusion that my processor is bad. I have changed the motherboard, ram, ssd and the power suplly and still get the same MEMORY MANAGEMENT error. I have checked all of the settings in the bios and are fine. I have had this machine for 3 years and never had this problem until recently. The only thing that is still original is the cpu and I still get the exact same errors. Is there an app that will test the memory manager on an i7? Does Intel have a core charge program for replacing bad processors?
Allan_J_Intel1
Thanks for joining the Processor community.
If you would like to run diagnostics on your processor, please use the utility below:
http://www.intel.com/support/processors/sb/CS-031726.htm Processors — What is the Intel® Processor Diagnostic Tool?
If you are still having processor issues, my recommendation is to contact Intel Customer Support for warranty replacement of your processor. You can use our Web Ticketing system to do that.
Online warranty:
https://servicerequestmgmt.intel.com/webticketui/emailpage.aspx Service Request Email
Allan.
