Hello Community!
I have a question about upgrading i7 4700MQ. Currently I have a Lenovo G510 with i7 4700MQ. Everything works great except that the current processor doesn't support VT-d (as far as I know). I have search for some references and found out that i7 4700MQ and i7 4800MQ are quite similar (please correct me if I'm wrong). Therefore I wonder if it is possible to simply upgrade the processor. If it couldn't be done, I wonder if there is a way to enable VT-d within my laptop.
Any suggestion would be appreciated. Thanks a bunch!
They are socket compatible: http://ark.intel.com/compare/75128,75117 http://ark.intel.com/compare/75128,75117
Also, the i7-4800MQ supports VT-d where the i7-4700MQ does not.
However, you need to ask Lenovo if their BIOS supports the i7-4800MQ. Otherwise, you may find that it works, or only works partially, or does not work, or has damaged your motherboard.
Doc
Doc
Hi Doc,
thanks for the answer. So it seems that the risk does't worth the try. I've tried asking Lenovo support couple of times and they seem hesitant about the topic. Regardless, thanks again.
Al Hill is right about this, the processor can similar and as well compatible with the socket but the BIOS in your laptop may not recognize the new processor and the laptop may never boot. You need to double check that your BIOS will support it. Some BIOS are very sensitive.
Best wishes,
Ivan
