Is anyone know i7-4790 cpu support window server 2019 ? I need to
Chung5800, Thank you for posting in the Intel® Communities Support.
In reference to your question, there is no restriction for the Intel® Core™ i7-4790 Processor to work with Windows* Server 2019, the Intel® Processor is actually compatible with any Operating System. The compatibility of the Operating System will depend on the Intel® Chipset located on the motherboard, the manufacturer of the motherboard is the one that will be able to confirm if in fact is fully compatible with Windows* Server 2019 and if they have the proper drivers for this configuration, so the best thing to do will be to check directly with them to confirm those details.
Albert R.
