Processors
14530 Discussions
i7-6500u SST disabled
DMcGo1
I have an I7-6500u in a HP spectre 15-ap004na
I am on windows 10 enterprise version 1607
I am of the understanding that the speedshift technology should be available and enabled on this combination.
However in HWINFO it is in red (which i think means available but not enabled)
I cannot see anyway to turn this feature on.
Hello The_seraphim,
Thank you for contacting the Intel community.
The option is normally located on the BIOS, depending on the motherboard you are using and how your system was built, the Intel® speed shift technology is available on 6 generation processors but this also depends on your computer manufacturer if they decide to enable or disable this option.
At this point, I suggest you to contact you computer manufacturer and find out if this option can be enabled on your system BIOS, you can check with them if there is a BIOS update that can help enable this option on your system.
Please let me know how it goes.
Ivan.
Hello The_seraphim,
Ivan.
