Processors
13552 Discussions
i7-6700 Kb 3.40Ghz
billywhizz
Got a problem with installing Windows 11. I comply with all r requirements except my i7-6700 Kb 3.40Ghz  Processor. When I check on Windows 11 list of compatible Intel Processors, low and behold mine appears on it ! So why the hell does windows keep telling me that they don't support it for Windows 11 installation. I run windows 10 Professional at the moment. PLEASE...PLEASE................ CAN ANYBODY HELP  !!
AlHill
Your processor is NOT supported by Windows 11 nor is it on the list of supported processors:
https://docs.microsoft.com/en-us/windows-hardware/design/minimum/supported/windows-11-supported-intel-processors
And, you should expect to have problems.
https://support.microsoft.com/en-us/windows/installing-windows-11-on-devices-that-don-t-meet-minimum-system-requirements-0b2dc4a2-5933-4ad4-9c09-ef0a331518f1
[Windows 11 is the new Vista]
AlHill
billywhizz
Thanks AlHill for your prompt reply. You may well be correct, but I'm a little puzzled. On the face of it you appear to be using a different compatibility list to the one that Microsoft supply a link to in the rejection notice in the settings update section of my computer, here's the link:   (May have to copy & paste) Windows Processor Requirements Windows 10 21H1 Supported Intel Processors | Microsoft Docs  Look under Windows 10 2004 or Windows 10 21H1. This is what's confusing me. I'd be grateful for your advice, many thanks.
AlHill
The list you linked to is a Windows 10 processor compatibility list, not Windows 11 list.
Whatever the case, you should contact Microsoft, as it is their list.
billywhizz
Well AlHill,
I'm even more confused now. The link was supplied to me via the non-compatible rejection notice after using the Microsoft compatible check app. As I understand it the list on their supplied link states the windows 10 installed processors compatible and capable of converting the Windows 10 OS over to Windows 11 OS, is this not so ?
AlHill
Ask Microsoft.
billywhizz
Tried MS but trying to get a solution from Microsoft is akin to attempting to "push water uphill"......... but thanks for trying to help, I appreciate it.
AlHill
Let me repeat.  Your processor is not supported by Windows 11 as is confirmed in the Windows 11 compatibility list.  Whatever else is going on is for you to solve with Microsoft.   Since your processor is working, this is not an Intel issue or problem.  You can go to the Microsoft support forum for Windows 11 and post your question there.  But, the answer will still be that your processor is not supported on Windows 11.
You are supported on Windows 10, and it is very unlikely that you need anything from Windows 11.   And, on a personal note, I am on Windows 11 and I can tell you for certain that you are not missing anything.  I have five other machines that are Windows 11 capable, and I am leaving them on Windows 10 to avoid the pain and discomfort Windows 11 brings.
None of this stops you from running Windows 11.  You have read about the one line registry hack that Microsoft published, correct?   I am not saying you should use it.  But, if you feel you must, be my guest.
https://www.onmsft.com/news/microsoft-back-off-requirements-windows-11
Do not say that I did not warn you.
