Processors
14405 Discussions
i7-7700k hummidity
DJung4
I want to know the operating humidity of the CPU.
CPU name is i7-7700K.
AlHill
Well, it cannot run without a motherboard and proper cooling system. So, what motherboard do you have?
Doc
DJung4
Of course.
I am using IMB-191 (ASRock).
AlHill
I cannot find the humidity specs for your motherboard, which I assume would be more important. All I see is the operating temperature.
I checked the datasheets on the processor, and could not find humidity specs.
So, you should contact asrock for the environmental specs on the board, while we wait for one of the intel support engineers to comment on the humidity specs for the processor.
For the board to not specify the humidity specs seems unusual to me, since it is an industrial board.
Also, I have moved this to the forum.
Doc
Hello, everyone!
daniel74: Since the Intel® Core™ processors are intended for home use, they should be able to handle indoor humidity without any problem. It does not matter the zone or climate, if it is used as it should be, the humidity will not generate any issue to the unit.
Then, humidity is important for packaging or storage. Are you looking for this information for this purpose?
Antony S.
DJung4
Is it safe to use in 75% humidity environment?
n_scott_pearson
Well, the processor is, but I don't know about the motherboard or other components (my guess would be marginal).
