Processors
14534 Discussions
i7-8700 24bit/192 khz support
HBace
I have one Intel i7-8700 with a motherboard Asrock Fatal1ty Z370 Gaming-ITX/ac and everything is just working fine in a windows 10 Pro.
However the only issue that i found is that when i connect the computer to a av receiver capable of mentioned format by the onboard hdmi the output format 24bit - 192 kHz is not available in windows. The drivers installed are the latest available. I have a old pc that can do this without any problem. So the receiver is not the problem.
I thing this is an old issue because i can see several posts in the community forum without resolution or solution. There are any expected date to fix this issue?
Hugo
HBace
In 8th Generation Intel Processor Datasheet (https://www.intel.com/content/www/us/en/processors/core/8th-gen-processor-family-s-platform-datasheet-vol-1.html 8th Gen (S-platform) Intel® Processor Family Datasheet Vol.1) page 42 is refered that the processor support LPCM 192 kHz.
n_scott_pearson
That is correct; the hardware is capable of supporting this configuration -- but the Windows driver does not support it. When last the issue came up in discussions, the drivers team told us this wouldn't be fixed in the near term.
Sorry,
HBace
Hi Scott,
There are any reason for that?
In a world where streaming and high resolution audio files are the future, why intel don't do this? There are any known workaround for this issue?
Hugo
n_scott_pearson
Well, I could speculate, but that doesn't solve anything. The only workaround is to use lower quality audio. That's all you can do until they fix this.
