Hello guys, i'm getting temps on my CPU i7 8700 non (K) around 90 degrees. i'm doing some 3D rendering stuff.
my cooler is CRYORIG C7 and my build is ITX mini.. is this temperature is safe for this CPU? thanks guys
Hello Gotchie15,
Thank you for joining this Intel Community.
I understand that the temperature of your processor increases when you run 3D rendering applications. I would like to provide more information about this issue.
According to https://ark.intel.com/, your Intel® Processor is running within specifications. This means that the temperature you are getting should not damage your processor or other components in your computer. You can check this under the Product Specification page of the processor, click Package Specifications to determine Tjunction, the maximum temperature allowed at the processor die.
https://ark.intel.com/products/126686/Intel-Core-i7-8700-Processor-12M-Cache-up-to-4_60-GHz
Because you are running demanding applications, the processor is capable of generating a fair amount of heat. However, to make sure it is working correctly, please run the Intel® Processor Diagnostic Tool and attach the report. This will allow us to review your system environment and processor functionality.
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
Also, please scan your system using the Intel® System Support Utility to get useful information about your computer.
1.Download the Intel® System Support Utility and save the application to your system.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91...
2.Open the application and click Scan to see system and device information. The Intel® System Support Utility defaults to the Summary View on the output screen following the scan. Click the menu where it says summary to change to Detailed View.
3.To save your scan, click Next and click Save. You can save the file to any accessible location on your computer.
4. Attach the report to this thread.
Wanner G.
hello Wanner,
i don't know how to attached the save file system of my computer. so if you don't mind i just copy all the detail below. please bear with me on this.
and thanks for your help. i appreciate it
regards
# SSU Scan Information
Scan Info:
Version:"2.5.0.12"
Date:"07/20/2018"
Time:"00:00:22.8592458"
# Scanned Hardware
Computer:
BaseBoard Manufacturer:"ASUSTeK COMPUTER INC."
BIOS Mode:"UEFI"
BIOS Version/Date:"American Megatrends Inc. 0401 , 03/21/2018"
CD or DVD:"Not Available"
Embedded Controller Version:"255.255"
Platform Role:"Desktop"
Processor:"Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz , GenuineIntel"
Secure Boot State:"Off"
SMBIOS Version:"3.1"
Sound Card:"NVIDIA Virtual Audio Device (Wave Extensible) (WDM)"
Sound Card:"NVIDIA High Definition Audio"
Sound Card:"Realtek High Definition Audio"
System Manufacturer:"System manufacturer"
System Model:"System Product Name"
System SKU:"ASUS_MB_CNL"
System Type:"x64-based PC"
- "Display"
Intel ® Graphics Driver Version:"Not Available"
- "NVIDIA GeForce GTX 1080"
Adapter Compatibility:"NVIDIA"
Adapter DAC Type:"Integrated RAMDAC"
Adapter RAM:"4.00 GB"
Bits Per Pixel:"32"
Caption:"NVIDIA GeForce GTX 1080"
CoInstallers:"nvdispgenco6439836.dll,NvGenericCoInstall,nvdispco6439836.dll,NVDisplayCoInstall"
Color Table Entries:"4294967296"
Dedicated Video Memory:"Not Available"
Driver:"nvlddmkm.sys"
Driver Date:"06/24/2018 08:00 AM"
Driver Path:"C:\WINDOWS\system32\DriverStore\FileRepository\nv_dispi.inf_amd64_485c1c3102021986\nvlddmkm.sys"
Driver Provider:"NVIDIA"
Driver Version:"24.21.13.9836"
INF:"oem27.inf"
INF Section:"Section102"
Install Date:"Not Available"
Installed Drivers:"C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_485c1c3102021986\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_485c1c3102021986\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_485c1c3102021986\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_485c1c3102021986\nvldumdx.dll"
Last Error Code:"Not Available"
Last Error Code Description:"Not Available"
Last Reset:"Not Available"
Manufacturer:"NVIDIA"
Microsoft DirectX* Version:"DirectX 12"
Monochrome:"No"
Number of Colors:"4294967296"
Number of Video Pages:"Not Available"
PNP Device ID:"PCI\VEN_10DE&DEV_1B80&SUBSYS_85AA1043&REV_A1\4&2D78AB8F&0&0008"
Power Management Capabilities:"Not Available"
Power Management Supported:"Not Available"
Refresh Rate - Current:"143 Hz"
Refresh Rate - Maximum:"143 Hz"
Refresh Rate - Minimum:"23 Hz"
Resolution:"2560 X 1440"
Scan Mode:"Noninterlaced"
Service Name:"nvlddmkm"
Status:"OK"
Video Architecture:"VGA"
Video Memory:"Unknown"
Video Processor:"GeForce GTX 1080"
- "Memory"
Physical Memory (Available):"12.30 GB"
Physical Memory (Installed):"16 GB"
Physical Memory (Total):"15.92 GB"
- "BANK 0"
Capacity:"8 GB"
Channel:"ChannelA-DIMM1"
Configured Clock Speed:"2400 MHz"
Configured Voltage:"1200 millivolts"
Data Width:"64 bits"
Form Factor:"DIMM"
Interleave Position:"First position"
Manufacturer:"Corsair"
Maximum Voltage:"Not Available"
Memory Type:"Unknown"
Minimum Voltage:"Not Available"
Part Number:"CMK16GX4M2A2400C14"
Serial Number:"00000000"
Status:"Not Available"
Type:"Synchronous"
- "BANK 2"
Capacity:"8 GB"
Channel:"ChannelB-DIMM1"
Form Factor:"DIMM"
Interleave Position:"Second position"
Type:"Synchronous"
- "Motherboard"
BIOS:"0401, ALASKA - 1072009"
Caption:"Motherboard"
- "Chipset":"Intel(R) 300 Series"
<spa...
Hello Gotchie15,
Thank you for your response.
It is fine if you copy the report on the thread. Could you also run the Intel® Processor Diagnostic Tool and attach the report. To save the report click on File > View Results File > Save the text file.
In case you are still unable to attach the report, I will send you an email.
Wanner G.
Hello Gotchie15,
By reviewing the report generated by the Intel® Processor Diagnostic Tool, we can gather key information about your system.
I will be glad to assist you if you still need assistance.
Wanner G.
Hello Wanner G.
I’m not use to write on blogs so please forgive any communication errors.
I have Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz on my HP EliteOne 800 G4 23.8-in Touch AiO with Windows 10 Pro 64 bit Versione: 17134.765.
I also find a bit high temperature (around 90°C) running just the Windows app Foto (or Photo in English?), could be a normal behaviour ?
I followed your suggestion above running test SSU and IPDT. I tried to attach the reports but it doesn'work, so I could send them by email as you suggested to Gotchie15
Thank you very much for your feedback about
