I would like to fix the increase frequency of the notebook processor from 4.10 gHz to 3.4 gHz. I want to make a heat drop under the load. I want to keep the frequency from falling too much.
You aren't offered a way to configure this in the BIOS?
Your choice then is to use XTU, Intel's eXtreme Tuning Utility.
Hello hakbu,
Let me know if you need more assistance.
David V
A Contingent Worker at Intel
I've used XTU, Intel's eXtreme Tuning Utility. But the limitation on applications doesn't work.
Game or application.
Hello hakbu,
Thank you for your response.
The option that you are looking for must be set within the BIOS, I would recommend contacting the motherboard or system manufacturer for more options related to this.
David V
Hello hakbu,
What do you mean with properties? Where you able to contact the system manufacturer?
David V
Hello hakbu,
Please contact us if you have any additional questions.
David V
