Processors
14506 Discussions
i7 8750h turbo boost
hakbu
I would like to fix the increase frequency of the notebook processor from 4.10 gHz to 3.4 gHz. I want to make a heat drop under the load. I want to keep the frequency from falling too much.
n_scott_pearson
You aren't offered a way to configure this in the BIOS?
hakbu
bios does not have such an optimization 10 Ağu 2019 Cmt 20:42 tarihinde Intel Forums <supportreplies@intel.com> şunu yazdı:
n_scott_pearson
Your choice then is to use XTU, Intel's eXtreme Tuning Utility.
hakbu
restricts when testing applications not working on 11 Ağu 2019 Paz 21:39 tarihinde Intel Forums <supportreplies@intel.com> şunu yazdı:
n_scott_pearson
You'll have to explain that (cryptic) response.
David_V_Intel
Hello hakbu,
Let me know if you need more assistance.
David V
A Contingent Worker at Intel
hakbu
I've used XTU, Intel's eXtreme Tuning Utility. But the limitation on applications doesn't work.
Game or application.
David_V_Intel
Hello hakbu,
Thank you for your response.
The option that you are looking for must be set within the BIOS, I would recommend contacting the motherboard or system manufacturer for more options related to this.
David V
hakbu
properties 16 Ağu 2019 Cum 20:18 tarihinde Intel Forums <supportreplies@intel.com> şunu yazdı:
David_V_Intel
Hello hakbu,
What do you mean with properties? Where you able to contact the system manufacturer?
David V
David_V_Intel
Hello hakbu,
Please contact us if you have any additional questions.
David V
