Processors
16296 Discussions
i7 980x heat-sink options
The heat-sink that ships with the i7 980x is just a little too tall for the box we desire to place it in. . . Are there any heat-sinks that are a little wider instead of taller to offer the same cooling capabilities. Are there any other heat-sink options for the i7-980x??
What case do you have? Because its only 124mm tall which is smaller then a Arctic Cooling Freezer 7.
You will unlikely find a vertical cooling type heatsink and may be limited to a horizontal cooler.
Noctua NH-C12P SE14 114mm tall (with fan)
http://www.noctua.at/main.php?show=productview&products_id=35&lng=en&set=1 http://www.noctua.at/main.php?show=productview&products_id=35&lng=en&set=1
Thermaltake ISGC-400 101mm tall (with fan)
http://www.thermaltake.com/product_info.aspx?PARENT_CID=C_00001391&id=C_00001392&cid=C_00000010&name=ISGC-400&ov=n&ovid http://www.thermaltake.com/product_info.aspx?PARENT_CID=C_00001391&id=C_00001392&cid=C_00000010&name=ISGC-400&ov=n&ovid=
