Hello maximum1st,
Our support is only provided in English. To better assist you, we use a translation tool; hence, the translation may not be completely accurate. Let me know if the following is a correct translation of your post:
"i7 Z170 Max CPU
I'm currently using an i7 6700, and my chipset is the Z170, but how far can I use the CPU?"
If it is correct, let me know what you exactly mean by saying: "how far can I use the CPU?"
Jean O.
Hello maximum1st,
I hope you are doing fine.
Jean O.
Hello maximum1st,
I have not heard back from you. So we will close this thread. If you need any additional information, submit a new question, as this thread will no longer be monitored.
Best regards.
Jean O.
