What is wrong here during the stress test I immediately get a Thermal Throtting and the temperature immediately runs to 100 degrees I had to interrupt the stress test because I do not want to run a risk.
Without the stress test or benchmarking, it's quiet.
What can I do best to prevent this, on the internet there are several options given to adjust turbo boost, for example, but I don't know with which settings I should set it, please help me.
EvertPrakkie, Thank you for posting in the Intel® Communities Support.
We will be more than glad to assist you with this matter.
For this scenario, it is important to mention that the T-junction for the Intel® Core™ i9-13900F is 100°C, which means that any temperature result lower or equal to that value is considered normal and expected for this unit:
Additionally, based on the pictures, we can see that you are using the Intel® Extreme Tuning Utility, and in this case, it is also necessary to note that your processor is not fully compatible with that tool, so there could be a misreading while running that application:
https://www.intel.com/content/www/us/en/support/articles/000057552.html
In order to rule out any possible hardware issue with your processor, please install and run the Intel® Processor Diagnostic Tool. It does an overall test on the unit and if it passes the test it means it is working properly:
In regards to the option of adjusting turbo boost, we always recommend to use the computer at stock configurations with the default BIOS settings, there is no need to change those settings for the optimal functionality of the processor.
Additionally, just in case, in the link below you will find "Overheating Symptoms and Troubleshooting for Intel® Boxed Processors" with further details on this subject:
Albert R.
Hello, @EvertPrakkie
We hope you are great.
I am checking this thread and I would like to know if you were able to review my previous post.
Jocelyn M.
I hope you are doing great.
As we have not heard back from you, we will proceed to close this thread now.
If you need any additional assistance, please feel free to contact us back and submit a new question as this thread will no longer be monitored.
Jocelyn M.
