I have an Intel i9 13900ks processor along with rtx 4080, a 1200w power supply, a z790 ddr5 motherboard and a 240mm liquid cooler.
My cpu temperature is going around 90 degrees celcius( occasionally spiking up to 93-94) while gaming.
I've searched online but half of the internet is saying these processors are made to run hot and the other half are saying this is an issue.
Can someone let me know if this is an issue and if so how should I troubleshoot it?
Hello SatvikWatts,
For overheating issues, we have this link that you can check and follow:
Michael L.
Hello SatvikWatts,
Michael L.
Hello SatvikWatts,
I am sending another follow up to check if you tried our recommendations.
Michael L.
I'm having the same thermal issue with my 13900 i9. I'm just idling on my desktop with no applications running; I'm hitting 100c. When I'm in the bios, I hit over 90c. It doesn't make any sense. I've tried a ton of different troubleshooting steps online, but nothing has fixed it. I'm close to changing over to an AMD chip since I had no issues with that chip.
Any help would be highly appreciated, though I've already received a return label for the CPU in my inbox. Yes, my CPU cooler and thermal paste are installed correctly.
