Hi All,
I've seen some recent posts here describing the same issue as I have, but I wanted to get some more information on this.
My setup:
i9 14900k
Deepcool LT720
MSI Z790 Tomahawk Max Wifi
G-Skill DDR5 6400mhz
The power limits are set as followed:
PL1/2 253
-0.100 undervolt
MSI AC/DC 60/80
Whenever I run Prime95, OCCT or Handbrake Video Encoding, the temperatures stick to around 85 degrees in heavy workload, but whenever I export video in Media Encoder, or run a Cinebench benchmark, one or two cores keep triggering the thermal throttle warning in HWiNFO. Everything is hovering between 75/85 degrees but, most often Core 7, it still thermally throttles.
Even when setting PL1/2 to 200, limiting cores to 56/41 multiplier or with just the intel default settings, it keeps popping up.
Is this avoidable, or is this even a serious issue?
Thanks in advance for your help
Hi @FridgeMagnet ,
Did you lower the limit for thermal throttling to 80°C?
I just looked at one screenshot, but the cores did not reach anywhere near 100°C.
