Ive gotten a lot of blue screens. stopcodes CLOCK_WATCHDOG_TIMEOUT, and irql_not_less_or_equal.
Ran Windows 10 then upgraded to 11 in hopes of fixing things.
Ive update all I can with drivers.
No OC.
My PSU is more than powerful enough with 850W while running an MSI Aero 1080 OC while also trying my EVGA 1080 FTW 3.0. I run 32 GBs of Corsair Vengeance RGB DDR5 6000 MHz
also Thermalright Aqua Elite 240 White V3 for my cooler.
I have an El Gato HD 60 Pro as well.
I've ran diagnostics to test my parts and everything came back working.
I've reinstalled the programs, even on different SSDs.
I ran Cinebench R24 and have only gotten results for my GPU and single core processing. But it would crash during multicore processing.
I tried running Cinebench R23 but I gets an error.
I've come to the conclusion of it being the processor.
Try to use power saving power plan in windows power settings, if the crashes stop then get RMA or refund because it is probably the CPU being faulty.
I bought it off OfferUp. Unless Intel still supports the buyer regardless of where it was purchased, then I might've wasted my money. AMD might be a legit move.
If you bought it off OfferUp, then you are technically the second owner of this processor - which means that you have no warranty at all.
Sorry, reality bites.
