Community
cancel
Showing results for
Search instead for
Did you mean:
AVolo2
i9| i7 8700| ES of Xeon e5-26xx v4
Hi all,
To run Tensorflow GPU , and convolution network GPU algorithms I am considering processors:
1) i7 8700
2) i9 7900x
3) xeon e5-2690v4 ES
Needless to say that I am a poor student and would rather prefer being given processors for development than to spend my pocket money for processors instead of lunches.
However, what of the above could you advise?
In particular it is interesting how Q1/16 xeon ES will correlate with performance of Q4/17 of i7 8700 and Q2/17 i9-7900x.
While the performance of https://www.ebay.com/itm/Intel-Xeon-E5-2690-V4-ES-QHV5-2-4GHz-14Core-135W-35MB-LGA2011-3-Processor-C... ES is doubtless better,but it has used state , though with a price of https://www.intel.com/content/www/us/en/products/processors/core/x-series/i9-7900x.html i9-7900x. The latter seems reducing price within time. However, https://ark.intel.com/products/126686/Intel-Core-i7-8700-Processor-12M-Cache-up-to-4_60-GHz i7 8700 appears to be the most recent one, but evidently less performative than both of the mentioned before, and significantly cheaper. Moreover Intel seems to introduce Xeon D series. That makes the choice much more complicated, in my opinion.
May be Intel could provide some engineering sample for development or testing on whatever conditions?
https://www.intel.com/content/www/us/en/products/compare-products.html/processors?productIds=123613%... Compare Products
It seems that apart of difference in prices they belong to different class [desktop/server]
Moreover, apart of GPU computations I have an interest in virtualization hypervisor. In particularly interesting to me seems the issue of delivering of virtual desktop over the network.
If I have http://GA-H61M-S2V-B3/ GA-H61M-S2V-B3 with
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 4
On-line CPU(s) list: 0-3
Thread(s) per core: 2
Core(s) per socket: 2
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 58
Model name: Intel(R) Core(TM) i3-3225 CPU @ 3.30GHz
Stepping: 9
CPU MHz: 3292.437
CPU max MHz: 3300,0000
CPU min MHz: 1600,0000
BogoMIPS: 6584.87
Virtualization: VT-x
May be I shall rather consider upgrade to https://ark.intel.com/products/97128/Intel-Core-i7-7700-Processor-8M-Cache-up-to-4_20-GHz i7 7700 as the most economically beneficial with less expenses? Because all other mentioned options will involve substitution of motherboard and memory and corresponding elements including power supply. Or rather I shall wait until more performative and affordable models come up?
Kind Regards,
Andrei
Community Manager
Hello Andrey_nsk,
I understand that you are looking for the best processor to use tensorflow and other.
Regarding this, I would strongly suggest to check on the tensorflow website and see if they have the requirements of the processor needed. Any processor with the recommended requirements or above should work just fine.
Also, here is a comparison between the processors:
https://ark.intel.com/compare/91770,126686 https://ark.intel.com/compare/91770,126686
The Xeon* processor has made specially for heavy tasks and use as they are meant to be used for workstations and heavy applications. Still the 8700 should work just great but the Xeon* is the best for heavy duty and/or applications.
David V
AVolo2
Dave,
Thank you for your response.
I understand that you draw my attention to two possible candidates as xeon e-52690v4 and i7 8700.
I do not necessarily look into tensorflow performance particulary, moreover I am rather concerned in GPU version of tensorflow. However running of virtualization and sophisticated algorithms could load cpu as well as GPU, in my opinion.
Basically Google seems to use https://cloud.google.com/blog/big-data/2017/05/an-in-depth-look-at-googles-first-tensor-processing-u... TPU processors that are available in the cloud, but their programming language will execute on any architecture like x86_64 or arm, as it seems to me.
Thank you for the explanation regarding concern and target use of the mentioned processors.
As Xeon* processor has been made for heavy tasks and persistent heavy load possibly they should be the best fit for convolution networks training, as it seems to me.
Kind regards,
Andrei
Community Manager
Hello Andrey_nsk,
Thank you for your response,
That is quite correct, according to your description the best option would be to go with Xeon* as it is meant to work for hours without problems and heavy-duty applications, as mentioned before however, remember to check the requirements of the processor to make sure it suits your needs.
David V
AVolo2
David V,
In oriental world I have found at auction
some xeons items that seem affordable
but sellers can not verify operability of the cpu's
[if they work or not]
Could you based on S/N confirm that the cpu's actually belong to the e-5 v4 family of xeons and do not appear to be fake, please?
Item 1:
Item 2:
As I have mentioned I am a poor student and only xeon cpus I can afford are used auction ones. Since you couldn't offer educational discount any help with distinguishing if listed cpu's appear valid will be appreciated.
n_scott_pearson
Super User Retired Employee
The identifier appears to be correct. My concern would be that these are ES - as in Engineering Sample - processors. The first problem with ES processors is thst they are early stepping parts. The second problem is that most motherboards do not carry microcode for ES parts.
I would not purchase anything without formal guarantee that (a) the parts work and (b) the parts are not engineering samples.
AVolo2
N. Scott Pearson,
As a matter of fact as long as sellers can verify [formal guarantee] that parts work, they rocket prices.
For example one of the above can be approached with bid 40, and the other with 200.
Moreover, sellers that can verify items to work have prices like 700+ for ES.
However, If Intel could offer 50% educational/research discount I would get a new retail xeon e-5 2690v4.
But nevertheless, thank you for your opinion.
Should I stick to use of the i3-3225 CPU @ 3.30GHz that I have and give up with the idea to get a xeon , presuming I am limited in budget?
Are there particular motherboards that are likely to support ES microcode?
Could you confirm the rows of capacitors at the bottom to correlate with the model numbers at the top heater, please?
n_scott_pearson
You'll need to talk to Intel about verification - and that discount...
AVolo2
Is communities.intel.com the right place to talk to intel pertaining to the verification/discount?
n_scott_pearson
For the identification, right here - but not on the weekend. As for discounts, no idea.
AVolo2
Thank you for letting me know!
AVolo2
I have found an offering of E5-2679v4.
It has TDP 200W. However, most of motherboards are "up to tdp 160w", as it seems to me.
I mostly checked supermicro motherboards.
I am just wondering what cooler could you suggest for E5-2679v4?
What is the operational temperature for that CPU?
What motherboards does it fit well?
Thank you
Andrei
Community Manager
Hi Andrey_nsk,
I have answered using the forum /thread/125442 what is the operational temperature for E5-2679v4 and how to maintain it? requesting this information.
I requested additional time to get further details of this special processor Intel® Xeon® Processor E5-2679v4.
Andrey_nsk, please allow me to continue supporting your request using the first forum.
Miguel C
Intel Customer Support
