It doesn't appear the the Intel AES NI hardware acceleration is working on Intel® Xeon® Processor D-2733NT or D-1718T running RHEL 9.1.
I installed the QAT driver QAT20.L.1.0.10-00005 using the "./configure --enable-qat-lkcf" to register with RHEL crypto modules.
A few observations:
1) the qat service status says qat_service[20983]: There is 0 QAT acceleration device(s) in the system
2) openssl engine - does not show aes-ni present.... Only shows the following
(rdrand) Intel RDRAND engine
3) there is no kernel AES NI module per command
sort -u /proc/crypto | grep module
module : crc32c_intel
module : crc32_pclmul
module : crct10dif_pclmul
module : ghash_clmulni_intel
module : kernel
4) modprobe intel-aesni
modprobe: FATAL: Module intel-aesni not found in directory /lib/modules/5.14.0-162.6.1.el9_1.x86_64
5) mpicalc --print-config - this shows the intel-aesni available
hwflist:intel-cpu:intel-bmi2:intel-ssse3:intel-sse4.1:intel-pclmul:intel-aesni:intel-rdrand:intel-avx:intel-avx2:intel-fast-vpgather:intel-rdtsc:intel-shaext:intel-vaes-vpclmul:
fips-mode:n:::
rng-type:standard:1:3030000:1:
compliance:::
Are there instructions on how to invoke the intel-AESNI hardware acceleration for openssl in RHEL 9.1
Hello, Toby-GE-Aerospace,
Thank you for reaching Intel Communities. I will gladly help you.
I suggest asking posting your question in the Embedded Community: https://community.intel.com/t5/Embedded-Products/ct-p/embedded-products
In there, choose the Embedded Server forum. An Intel dedicated team will support you.
Allan
