Processors
15892 Discussions
intel core i5-1038ng7 Max Resolution
x-tivity
Hi All,
According to the spec sheet from intel website..
https://ark.intel.com/content/www/us/en/ark/products/196594/intel-core-i51038ng7-processor-6m-cache-up-to-3-80-ghz.html
I would like to understand that the max resolution of HDMI interface is hard limit or not. And, If I use HDMI 2.1 will it be able to support higher refresh rate and resolution or not?
Max Resolution (HDMI): 4096 x 2304@60Hz
Max Resolution (DP): 5120 x 3200@60Hz
I wants to achieve 5120 x 1440@120Hz with HDMI 2.1 to Thunderbolt 3 cable.
n_scott_pearson
Yes, these are hard limits. Your processor only supports HDMI 2.0b output, not HDMI 2.1.
Now, if you are using a TBT port, your output is actually in DisplayPort 1.4 format (this is being converted to HDMI by the cable assembly). In DisplayPort 1.4 output, you can, in theory, achieve 5120x1440@120Hz (see https://en.wikipedia.org/wiki/DisplayPort for more information). Whether you will actually see this after the cable's conversion is the question I cannot comfortably answer as I do not have any information on this TBT-to-HDMI cable's quality, etc.
Note: These results are limited to direct connection of the monitor to the TBT port. If you are using a downstream hub/dock/etc. - especially if USB is also being utilized - then all bets are off.
Hope this helps,
x-tivity
i see... so that why even i have thunderbolt 3 to hdmi 2.1, it won't work. but thunderbolt 3 to DP1.4 works. it's because in this case CPU interface limit to HDMI2.0b and DP1.4
thanks for clarification.
megan3000
Valued Contributor I
Please remember to not relay only on CPU specs and display specs...
It is very important to confirm what exactly the computer manufacturer enables "to be supported"... Let me explain... I have seen laptops with HDMI 1.4 ports, but the manufacturer "limited" video output to just 1080p 60hz despite the standard supports 4K at 24-30hz.
I  have myself a laptop with a processor 11th gen HDMI 2.0, but Lenovo decided to put just an HDMI 1.4 port...  I was aware of this since it is not a big problem for me, the laptop also has a USB-C supporting 4K at 60hz and that is enough for me...
I suggest to check the PC manual before any purchase and review the "video modes" or "supported resolutions" to see the full list
