Processors
14780 Discussions
intel core2 quad q8400 overheat
hi all , i already builded a new pc desktop , using intel dg43 nb desktop board , and intel core2 quad q8400 2.6 ghz , 4gb of kingston ram ...the question is on normal load the cpu temperature showing between 40 to 50 degree celciuc , but on heavy load when all cpu's works on 100% the temperature is going around 75 degree celcius..
i work on 3dmax and vray , and the temperature is going that hight while i am on rendering...
the question is : is it normal for the cpu temperature to go that high on heavy load ? or the temperature it should be lesser than that....
please help , and thanks for all....
It depends on many thing, ambient temp, airflow, tim etc. But your temps are fione under load
hi , and thanks for the help , if the temperature gone higher than 75 degree , is the pc will shutdown or it will restart?
and do you know any way to test the cpu if it is working as it should or not ....sorry i am new in this field ...and thanks again for your help..
Vegan
Both Intel and AMD processors will throttle back when they get too hot. Get a better chassis with more fans to keep the heat down as it can harm a lot of components.
Vegan
You might need a better chassis with better air flow. That and a better CPU cooler.
hi, and thanks for the help . i am using an original intel fan and cooler , i use to have before a dual core processor with a temperature reach around 40-41 c on normal load ... do you have an information if the quad core generate more temperature than the dual core ....
thanks...
This does not answer your query directly but I guess it will help.
Intel hosts live chat event with their experts where people can discuss Intel products technologies. The next event will be held around their core processors. I think that it will be a good platform to ask this or any other question. The next event is on 26th March at 9:30 am GMT. More info at
www.intellivechat.com/
thanks to all of you for the help you provide ...
have a nice day
hey i am also using same configuration
when i am rendering with mental ray temperature is going 80degrees centigrade
i think so many people are getting the same problem
do you have any solution?
TIM_S_Intel
Tcase is 76.3°C
Are you getting the temp from your BIOS?
May check for a BIOS update, if your processor FHS is properly seated, Your processor TIM .
Is this a new built system? What is your chassis>
Air flow is important, but you should not be adding chassis fans if you have a recomended TAC 2.0 case.
see:
http://www.intel.com/support/processors/sb/CS-031446.htm http://www.intel.com/support/processors/sb/CS-031446.htm
Yaa yesterday i updated Bios also
i changed heat sink also
i am not understandng why it's over heating, please give me solution, can apply it to cooling solution
is there any problem in processor
please help me
